RE: NTC3 steering link question? Please read
spurgear - i have 2 NTC3's and they both did that. here is a solution
the problem is caused by two seperate parts.
1st - the bellcrank bushings are too loose and need to be replaced with bearings. AE makes this upgrade and it can be found anywhere.
2nd - ur right about the ball cups. replace them with a set from RPM similar to the rear toe in ball cups. these will solve the problem
