Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
 NTC3 steering link question? Please read >
Old 11-11-2003 | 02:04 PM
Default NTC3 steering link question? Please read
Does any one else with a NTC3 notice that their is some loose play in the whole steering link assembly? The problem is the poor quality ball cups used. Is there any available upgraded heavy duty ball cups available?
Old 11-11-2003 | 03:33 PM
studysession's Avatar
Default RE: NTC3 steering link question? Please read
There are upgrades for every part on the TC3 - Just go to different sites like towerhobbies.com or some others and search around.
Old 11-11-2003 | 03:57 PM
Nitroaddict's Avatar
spurgear - i have 2 NTC3's and they both did that. here is a solution
the problem is caused by two seperate parts.
1st - the bellcrank bushings are too loose and need to be replaced with bearings. AE makes this upgrade and it can be found anywhere.
2nd - ur right about the ball cups. replace them with a set from RPM similar to the rear toe in ball cups. these will solve the problem
Old 11-11-2003 | 08:14 PM
ShOzz's Avatar
is this problem in the ready to run or the team kit as well, i thought the team kit came full bearings?
Old 11-11-2003 | 08:36 PM
shozz - it is with the team kit as well. all my ntc3 are team kits. and all have this problem, and all have bushings in the bellcrank. the bearings are only in the drivetrain
Old 11-12-2003 | 12:08 AM
ShOzz's Avatar
ok, i will probably end up on here asking about it again when that day comes thati getthe kit... lol at least now though i know it will be fixable.
Old 11-12-2003 | 06:42 AM
Do you know which model RPM ball cups will fit? I have to order it online.
Old 11-12-2003 | 09:13 AM
these are the best fit
http://www2.towerhobbies.com/cgi-bin...?&I=LXEV19&P=7
