RCU Forums - View Single Post - Webra .50 Alternative
Old 11-11-2003 | 04:47 PM
DarZeelon's Avatar
DarZeelon
Default RE: Webra .50 Alternative
DR,
Since the Webra is a tapered bore engine (ABN), the sloppy rich method is a no-no.
Read threads about break-in of such engines in old RCU and in Bill Baxter's OS support forum.
It is wrong and damaging to four-cycle such engine during break-in.
Slightly rich (+1/2-3/4 turn from peak RPM) for 15-30 minutes should be enough.
Then you can go full bore.
Only if you happen to fall upon a ringed Webra (it exists), should the four-cycle rich method be used.
The MVVS .49 is a better 3-D engine still.
