Originally Posted by
Skunkwrks
So did that yellow paper rub through clear into the gray.
Have you tried some polish compound to see if it buffs out?
Nice scheme and colors
Yeah whatever was on that paper or the paper itself rubbed or if there is a clear on the outside of the plane it transferred to the paper . The exact patterns of gray crap on the paper matches the same pattern on the fuse bottom .
it looks like paint or clear coat softened and bled into the yellow paper but I don’t think Carf puts and clear or any paint on the outside to my knowledge, unless it’s the special UV protectant coating that Mike said they needed to use to keep the flat neon magenta from fading , then that’s what transferred.
Either way it doesn’t buff out , it’s permanent .
always my luck, I never get a perfect looking plane, always something damaged or cracked or chipped
