RCU Forums - View Single Post - Mato M36B1 steering problem
Old 10-11-2021 | 03:57 AM
tomhugill
Make sure your gears are well greased. Check track tension is about equal. Other things you can do is swap the motors round. If this reverses the issue some new matched motors will help. You should also be able to trim your transmitter to help.
