RCU Forums - View Single Post - Building RC Airplane from Scratch
Old 10-17-2021 | 05:07 PM
RBACONS
1. First, just because the pdf looks small on your computer does not mean that it prints out that size. Try opening the PDF, doing PRINT, set the print options to 100% (it probably opened with FIT selected) and it should tell you how big the document actually is. Usually you can just have a large-format print-capable shop print the file and it will come out correct as long as they can do a true 1-to-1 print.
In addition, some plans will have a scale marking on them (i.e., |_______| = 1 inch) or indicate the actual wingspan of the model. Either can be used to check the print out to ensure it's accurate.
2. If it's a true scratch build, one would normally research the aircraft to find out what size tires it used. If its a plan build, then the plans would normally have the wheels shown on the plan and you can measure them. Generally, if the build is at say 1/4 scale, you would find wheels that most closely matched 1/4 the size of the full scale or the size of the plan's wheels. Pilots are a bit of a crap shoot. Again, just find one closest to the scaled-down size of your model. Generally, WWI pilots are slightly shorter than WWII pilots and are shorter than modern pilots.
