Originally Posted by
1QwkSport2.5r
Contrary to popular belief, the spent oil carries away very little heat. It doesn’t have the thermal capacity to do so in such minuscule quantities (micro droplets). Sorry to burst the bubble. You can control engine heat better via fuel mixture strength.
True... Oil does not carry heat away. What it MIGHT do, is provide better heat transfer from piston to liner, and it might reduce the generation of heat by reducing friction, but normally, if you measure really accurately, every percentage point oil over the absolute minimum will increase engine temperature by roughly 1,5 deg C or about 2F
That minimum, for glow fourstrokes, is around 10~12%, a bit depending on engine size and Nitro content.
