RCU Forums - View Single Post - Gee Bee Conquistador
Old 10-22-2021 | 08:37 AM
  #132
Matzito's Avatar
Matzito
the lower board dives in the frame during forming with vacuum, the air is sucked through these holes near the canopy
lower wing surface nearly ready
just 1 try, didn`t had over material so it was success that the 1st try was ok
quick cut and try
only glued at the outer corners, the inner structure is not glued, due to optical perfection
Already protected for further steps
I started to glas all surfaces with 55gr/m2 diagonal, just the wings had only 1,2mm Balsa so they needed 2 times 55gr, 1st diagonal 2nd dihedral
Planet (03-16-2022)
