Started the front of the turret as its the difficult section , all the other sides will be flat or slightly curved. Cut the plate joints with a dremel bur and cut back the front for the curve on the front plate.
Some filler and a rub down for primer.
Cut along line and below to put a curve in the front plate. Easier to make square then cut.
