RCU Forums - View Single Post - cortex pro setting that you are using
Old 12-05-2021 | 07:44 AM
jvaliensi
Originally Posted by DAN AVILLA
I had the same problem with my Ultra Bandit. Danny explained the problem. If you have a plane that requires a lot of down elevator with flaps and have the flaps down when powering up it will not initialize . I just make sure I have the flaps up when I power up the plane. Dan
I had the same issue with my Joker. I couldn't figure out why the Cortex wouldn't initialize. The LED just blinked white. Turns out I would turn the model on with the flight mode switched to landing or take-off. If I flip it to cruise then the Cortex would be ready. So, I put a preflight switch check on my transmitter start up to make sure I'm in cruise mode before I power up the model.
Danny and LA Jet guy were very helpful for this - Thank You!
