RCU Forums - View Single Post - cortex pro setting that you are using
Old 12-05-2021 | 09:51 AM
DAN AVILLA's Avatar
DAN AVILLA
My Feedback: (12)
Originally Posted by jesse2357
It intilizes every time. I can move the plane around around and the surfaces correct in the right directions. in flight when in a knife edge it won't lock in, it rotates either right or left and I'm constantly correcting for it. What is everyone who has a locked in feeling plane using for modes? are y'all running the Aileron and elevator in heading hold and rudder in rate? or just all rate mode?.
I have only used heading hold on a 3 d prop job to hover and it worked. In rate mode it will not correct flight tendency's just smooth out the flight. If you have a plane that in a knife edge the needs inputs I have fixed it with mix's. I do not like having to switch from rate to heading hold while flying. Heading hold can be dangerous at the wrong time. Maybe some one can chime it that has used it successfully . Dan
