Originally Posted by
Mpizpilot
I have the same engine, i would try a lower voltage battery. I run a 6.6 LIFE. Are you sure its not lean? How does it run on the ground? Try turning out your needles.
Dear friend, please, can you send me a picture of your ignition unit you have connected to the engine or tell me the its brand? Mine is Chinese made, instead I read in the ZDZ website that, they should use the Falkon unit.
For you, connected one or the other of the two wire on the spark plugs is indifferent or they have a sequence of position?
Many thanks
