Originally Posted by
causeitflies
Hey Gary, I see you are using the Thixo Flex which is supposed to be more shock resistant than the regular Thixo I use. I was thinking of trying the Flex. Do you notice much difference? The regular seems a lighter color than yours also.
Hi Mark,
It's the first time I used it. I did not realize it was the "flex" even though it says it right on the label. Maybe it will be better that the regular if it is more flexible and not brittle. It is a little thicker than Six10 for sure. I will have to try the regular THIXO next time and see.
Thanks, Gary
