Originally Posted by
RoKit
I have the same issue with a 30 year old Carl Goldberg Ultimate,,, no matter what I do
the covering simply dont shrink.
I am seriously considering to re-cover the whole plane,
but not sure what to use instead ?
How did you end up ?
Good morning,
The wrinkles went away when a heat gun was used - the sealing iron wouldn't do it.
Not sure what kind of covering you are working with, but I would try a heat gun.
You must work slowly and be sure not to burn the covering.
My particular situation was Ultracote - not sure what you're using, but some coverings may react differently.
Let us know how things work out for you and best of luck.
Merry Christmas,
Skeezix
