Originally Posted by
Skeezix4me
Rob - I've had luck with covering that is quite old before, so don't give up yet.
Year ago, Topflight made something called a 'Hot Glove' I think. It was a hand mitt used in conjunction with the heat gun to help lay the covering down when it was hot. You may try something like that?
I would encourage you to keep working with it and keep trying ....low heat and slow....much like BBQ!
Sure I will try and try again, However I suspect the covering will come loose in the summer temperature and sunshine.
I am using a cloth and trying to press down as I heat it but the glue does not stick to the balsa.
Will continue to heat and press...
