RCU Forums - View Single Post - hyper 7 pbs upgrade
Old 11-12-2003 | 12:26 AM
dagass
Default RE: hyper 7 pbs upgrade
Both the C-hub and the PBS have their strong points and weaknesses. PBS is so popular because it offers a degree of tuneability that the C-hub cannot match. The drawback to the PBS is a significant amount of twist/flex in the the front knuckles. The theory is that even though the Pivot Balls can be "tuned" with a greater degree of accuracy than the C-hub, the suspension geometry of the PBS changes through out the run because of the twisting and flexing in the front knuckles. The C-hubs on the other hand are in a fixed position and remain that way, which leads to a more consistent setup. The drawback to the C-hub design? Lack of adjustability as compared to the PBS. As for the ball ends breaking easily on the PBS, nope! Not a shred of truth to that rumor. I've blown a countless number of landings and have yet to replace a pivot ball.
So who do you believe? If you ask Mugen, they would probably tell you that Pivot Ball is the way to go because that's what the MBX 5 uses. Ask Ofna and they will probably say go with the C-hub because that's what they have designed into their flagship race buggy the Hyper 7 Pro. Kyosho, well they use the C-hub too, so who do you listen to? More important, does it really make a difference? To me, it does not. Most of us will probably never drive our buggies at a level where we can actually realize the difference between the two designs. Get what you like and go out and have fun. Remember, the biggest single difference between all of the buggies is the person driving them.
