Originally Posted by
tassos p
Hey Dave,
Not sure if Powerbox Sensor has telemetry output (I doubt it) but in any case with PB devices if you want to have telemetry output from Powerbox you need to use this device --> the Teleconverter-->
https://www.powerbox-systems.com/en/products/accessories/stromversorgung/teleconverter-s-bus-2.html .
I have tried it with PB Royal only and works perfectly. Please look at the pics below. Make sure you connect both the Jetcat sensor and PB to SBUS2 slot (not SBUS). Then change Jetcat to slots 1-14. 15 empty. 16-31 goes to PB.
Should be straight forward.
Tassos
Hi,
Same exact configuration and tx but nope. It only works if leaving PB on Slot 8 ID3. Everywhere I try to add Jetcat V10 also PB data do not work anymore.
Also Jetcat V10 alone does not work.
All perfectly set on Jetcat fadec (telemetry menu to Sbus2), sensor is fine, rx 7003sb is fine.
only difference: jetcat fadec V12....maybe?
Any additional idea or suggestion?
Thanks !🙂✈
