RCU Forums - View Single Post - Engine side thrust
Old 01-16-2022 | 05:22 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Side thrust on both IMAC and pattern airplanes. I have in the past as a quick fix for models that didn’t have enough right thrust to set up a mix but had limited success with it. I currently have a new Edge 540 awaiting test flights. I will not be painting the cowl until the right thrust is set correctly. Right now it is set to 2.5 degrees. Running a 3W 106 with full length pipes and a 26x12 tri blade prop I suspect I will need to add more.
