I only have 3 super scorpions and the correct cg is right in front of the main struts not the center of the struts, the jet has lost more movement on the elevators than recommended by instructions, do at least 3 flight modes for elevators from recommended to much more, when flaps are deployed the elevators going up at least 12mm,you have plenty power so don’t worry about that.good luck maiden the jet.
