Originally Posted by
Agrav8ed
I personally only run my smoke tubes out the end of the jet. I have not been in the hobby as long as some and I do not know if it creates less smoke or not. But I do know that there is less chance for spilling, overflow or siphoning back into the fuse and there is less of a chance for damage to my fuse or turbine because of a fire.
Tone
For an example, smoke oil nipples added after combustion in a muffler, either two-cylinder or four-cylinder two-stroke in acrobatic planes.
They can produce heat of near 325F just above the spark plug in say a DA120 so the exhaust temperature at one from the exhaust is were the smoke nipples are located.
There is enough heat in the exhaust stream to produce excellent smoke clouds while 3D flying at stall to full speeds.
I'm leaning more toward trying the rear of the exhaust cone, it will be cleaner for the plane in the long run.
