RCU Forums - View Single Post - cortex pro setting that you are using
Old 02-14-2022 | 12:18 PM
Dansy's Avatar
Dansy
My Feedback: (53)
Originally Posted by jvaliensi
Hi,
I have an X45 turbine FW Avanti with Cortex Pro installed. First flights were awesome. Afterwards, I changed the servo linkage for the ailerons and elevator. I moved the linkage in a couple holes in the servo arms. I did this beause I had to have the servo travel set to 50% or less to get the correct amount of servo travel.
Next flights were not so good. The airplane didn't respond like it did before. It seemed too sensitive. But the surface travel was the same.
I'm wondering if I need to increase the 'gain' for the Cortex Pro. I generally use 30 to 40% for cruise mode and a more for landing and take off mode. Do you think increasing the servo travel but not increasing the surface movement caused the airplane to behave differently?
BTW -I have many flights with my EFD version w/ CP and it it perfect, but the linkages are at the longest spot at the servo arms and the travel is cut by 50% or more. I use 30% travel for the Cortex channel.
Did you do a relearn?
