RCU Forums - View Single Post - Cya glue and waxed paper
Old 02-21-2022 | 09:53 AM
Truckracer
My Feedback: (19)
Originally Posted by R8893
Depending on far back you go, you'll probably find that waxed paper doesn't have as much wax as before. I have found that thin CA sticks to it, but the waxed paper does prevent the CA from getting to your plans. The other glues do not stick to the waxed paper.
75 year old Chuck
Yes, the newer waxed papers use a different kind of wax than what they used years ago. It is more solid, not waxy feeling. I've found that CA kinda sticks but the paper can easily be pulled off. I just used wax paper for a 100" glider build and it worked just fine with minimal problems. Clear plastic wraps might be a better choice these days but I'd use wax paper again. Look for a thicker clear wrap w/o texture or it can be a pain to handle.
73 year old Roger
This must be a senior citizen forum these days.
