Hi Gorilla Toast
Thanks for the feedback on my book. I hope you get to enjoy flying your 2 mtr. Do use one of the trimming techniques to make sure you set it up correctly. A badly setup model, even a 2 mtr, will not help to one bit! Which 2 mtr is it that you have got?
Flying at 150 mtr out is not easy to achieve initially and requires constant practice, preferably with someone to advise on how far out you are. The wind is a constant challenge when it is blowing across the flight path - which it always seems to be all the time! A small key chain camera or a GPS will help to let you know how far out your aircraft is.
Good luck.
