RCU Forums - View Single Post - 1/8 scale hydro to electric conversion help
Old 04-01-2022 | 06:07 PM
Hydro Junkie's Avatar
Hydro Junkie
Had to call in some re-enforcement on this one since I only had a rough idea. What I was told is this:
  • If you can't hold the motor by the end caps without burning your fingers, it's too hot. Now then, let's get to the details
  • Using a infra-red temp gun, your battery packs, ESC and motor(checked on the ends, not the cooling jacket) should be no warmer than 140 degrees, with cool water going through the boat
  • If the water is fairly warm(warm being over 70 degrees) it's not going to cool the electronics as well so you might see temps getting a bit higher, maybe to the mid 150s or so.
  • Be sure you're not "over-propping" your boat. Depending on the weight of the boat, a 55-57mm prop is probably the largest you should be trying to run
  • You might want to consider using a 200 amp ESC if you decide to really push the boats as my "expert" has recorded spikes up to around 170 amps with a data logger when the boat was jumping on rough water
Now, I've got a little bonus for you. My "Expert" has told me I can give you his contact information, if you want or need it. The restriction is it doesn't get put on the open forum so, if you're interested, let me know
