RCU Forums - View Single Post - IBU2 Ultimate
Thread: IBU2 Ultimate
Old 04-26-2022 | 11:48 AM
Panzerpaul's Avatar
Panzerpaul
Thanks Rich: I also got a quick reply from Ian of RC Tank Electronics in the UK (who is the US dealer for the IBU Boards). He said: This flashing sequence is called Extended Signaling and if you go to the setting files for a board, and find the Miscellaneous Setup, you will see the following at the bottom: Flasher=1;0=Extends signaling OFF, 1=Extended signaling ON. Change to 0 and the flashing will stop. If your board setting's file is missing this info, you can copy and paste it into the bottom of that section. Ian has always been superb with customer support and we at FRAG highly recommend him as a supplier. PP
