Originally Posted by
Viper1GJ
Here is what I sent Tom from my testing with amp meter on the F-16 XL gear.
I set these values into the LGC-15 and they seemed to work OK. The problem I had was the brakes needed more voltage to stop the jet and as I recall the LGC-15 was limited to 2S LiPo. So I switched to a different brake controller.
Gear times and amps for JP F-16XL gear.
JP (Shaun) says 1.8 amps for the F-16 gear from an FB response.
Here's the max values I saw when I tested the gear
RMG 13 sec 1.4 amps
LMG 13 sec 1.4 amps
NG 9 sec .8 amps
I just used TLAR to set the unload time, I don't remember what value I used but it just unloaded the jack screws a little.
Gary
The LGC can use up to 3s for gears and brakes. However, it shares a power connection so you cannot run 2s to the gear and 3s to the brakes.
Tone
