CARF Touch up paint
Hi,
I need to touch up some boogers on my wing, The wing is brand new. If I get CARF paint what are the steps needed to make it look good?
1. I figure I need to sand out the defects with very fine paper, like 1000G and 2000G.
2. For the small areas needing repaint is it okay to not use primer?
3. Assuming the colors match and I add their top coat clear, how do I blend it in so the tape lines are not seen?
4. What kind of thinner does CARF paint use? Does the paint come with instructions?
5. The area is only a couple square inches and two colors, will an air brush be enough?
Perhaps I can hire a painter, any recommendations for the Los Angeles area?
Thank you,
