RCU Forums - View Single Post - Replace brushless motor with larger motor
Old 06-29-2022 | 04:57 PM
ron_van_sommeren's Avatar
ron_van_sommeren
Originally Posted by stephensackro
... The motor is a Kv=1000rpm/volt motor. ...
... If I went to a 800 watt Kv=1000rpm/volt motor, would I get about the same rpm since both motors are 1000rpm/volt motors? ...
RPM, current and power would be slightly higher because the copperwire resistance in the bigger motor is lower, which leads to lower voltage losses in the motor.
Efficiency of a bigger motor is slightly higher because of aforementioned lower resistance and because the motor will operate closer to point of maximum efficiency.
Velocity_konstant_Kv of the new motor should not differ too much though, because both current and power drawn are proportional to Kv cubed, a very disproportional effect. Unless the power system can handle the increase of course.
E.g. a
05-10-15-20-25% difference in Kv would lead to a
15-30-50-70-95% difference in current and power drawn.
More expensive Name:  frown.gif
Size:  1.0 KB silly, realistic and hopefully instructive examples of risky changes in voltage (power of 2), pitch and prop-diameter (power of 4!)
Vriendelijke groeten Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
E-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
