RCU Forums - View Single Post - Replace brushless motor with larger motor
Old 06-30-2022 | 01:44 AM
Joseph Frost
Originally Posted by stephensackro
Would like to stay with the 3 cell batteries since I already have some. Just would like to find out what going to a bigger higher wattage motor would do to my flight times assuming I am using the same prop. Since both motors would be 1000kv motors, does the amperage, RPM, and wattage stay about the same? Only difference would be that the bigger motor would not have to work as hard and stay cooler? Would the bigger 800 watt motor only draw about 200 watts like the smaller one since it is spinning the same prop?
Bigger motor- more power is always better than being under powered and having to add dead weight to the nose of the model.
One of my recent creation, a larger Bi plane is a great example, initially fitted with "EF110" and model coming heavier than expected, I knew as soon as I hooked it up on thrust scale and E-meter it will be very marginal.
Minor upgrade to "EF160" did all the difference, still the same voltage but larger prop with abundance of power at 1.5 to 1. Easy fix.
E-meter with pull scale is easiest way to find out how good will it perform.
RPM/Current and Thrust checks using various props.
Easiest option was motor upgrade.
Massive improvement after motor upgrade.
In action - where it belong.
