RCU Forums - View Single Post - Learn RC problem Jeti
Old 07-02-2022 | 10:24 PM
affas's Avatar
affas
Default Learn RC problem Jeti
Hi,
I do have a Kingtech 180 G1 that has been in use before with my Jeti DS 24.
I did install it in my new build Mirce 1/4 F86 Sabre and started the Learn RC.
I do make trim in 25% steps and -100/+100 on ATV.
Following the procedures and storing "half expo" with button 2 everything looks correct
When I do try to start everything seems correct and GCU shows "Ready" when trim is at idle, full throttle stick and the GCU shows Starting and cooling swapping and when I do pull the stick to idle for normal starts the GCU shows Starting but nothing happens at all.
I have tried to swap to a new rx and new model but same there. I have tried different ATV but I guess there is just something that I miss out and don?t see.
Any tips from You guys?
Thansks!
