The ibu does not support barrel smoke.
if you want it to do that you are going to have to experiment to get it to work.
try plugging your smoke unit into the same plug as the barrel LED in parallel so they both trigger at the same time.
you may need to have the heating element powered all the time so it’s hot at the moment you fire, then the flash and smoke motor fan will fire at the same time.
