Just about ready, little heavier than expected thanks to its size (86x100cm) and heavy duty hardware used with 6+ meters of CF to make it riggid. Haven't got the correct size prop to suit the tiny motor so in the mean time going to use some modified ones on hand.
This is the first ever model I'm using this inferior prop fit (prop saver), I don't trust it but will see how it goes.
Ail. linkage made up.
123 grams, no battery.
