Originally Posted by
Espritman
Hi All
Just joined today. I have been reading the pages on this forum for awhile now to get info on my turbine issue. So this is my first post as I need help from you experts out there.
My Jetcat P20 sx turbine has been misbehaving on the occasional basis that it wont go to ready after run up and stays on the Learn LOW mode.
If I reset the ECU and re-learn the Spektrum Ix12 radio, then it will run as normal and behave perfectly and fly my little hawk with no problems.
Once it has shut down and I want to start her up again it goes to Learn LOW and does not hand over to stick control.
Any help anyone can shed to this will be appreciated greatly.
PS I was told to have the feed line 120cm long, and the power connector had to be all 3 pins soldered, which I have done.
Regards
Ameer
Hello,
Did you solved this problem with Learn Low ?
I have the aame issue time to time on P80.
Thank you
Kind Regards
Toni
