My only concern prior to maiden was the effect of power unit thrust line, took only some 40m to lift off the 12 kilo mass, the move of my landing gear 12cm closer to the CG also helped. More than pleased with the conversion, so much easier, just plug it in and off you go rather than messing up with the turbine compexity and filthy smelly kero.
(Magenta re-maiden as an EDF)
