Thanks. The kit came with semi-symmetrical, almost flat, airfoil. I can adjust the incidence by adding a shim on the trailing edge to see how it goes, then figure a permanent fix.
Have you had any experience with tricycle gear and vtail takeoffs? The nose wheel might be lengthened to give the wing a better angle of attack at takeoff, eh?
P
