Beechcraft Bonanza V35 wing angle of incidence?
Anyone know of a reasonable wing angle of incidence for a 36 in. wingspan Beechcraft Bonanza V35? Drawings available online show 0-4 degrees. I doubt the 0 degree incidence is right.
P
P
Thanks. The kit came with semi-symmetrical, almost flat, airfoil. I can adjust the incidence by adding a shim on the trailing edge to see how it goes, then figure a permanent fix.
Have you had any experience with tricycle gear and vtail takeoffs? The nose wheel might be lengthened to give the wing a better angle of attack at takeoff, eh?
P
P
My Feedback: (29)
The only V tails that I have flown are pylon racers and sailplanes, obviously no nose gear. However I have flown many old school pattern planes and found that having the nose gear too long with the wing at more then a degree or two will cause the model to bounce if not landed perfectly. I always adjusted mine so that at rest the wing ( symmetrical in this case ) was sitting at a negative of 1 degree. If your mains aren’t too far back from the CG this becomes a non issue.
