I am using a R7003SB receiver. Is there a way to plug my ignition switch into the sbus on the gyro as otherwise I’m limited to channels 1 and 2 of the receiver and these are already designated to elevator and aileron by the gyro. I have used channel 3 which is not used by the gyro for throttle.
Thanks, Neil
I’ve found the answer. I needed to change ports 1 & 2 on the receiver to 11 & 12 using the receiver manual
