RCU Forums - View Single Post - 3D Printed 1:16 E-100
Old 07-26-2022 | 07:28 AM
Durahl's Avatar
Durahl
Talking Final Update for the foreseeable time...
It's been a few more days since I was able of getting the model to stand onto its own... uhm... feet:
Unfortunately, the use of SLA 3D Printed Swing Arms has proven to be insufficient for the not even final weight model as over the course of just a few days they've experienced material creep causing the wheels to be pushed outwards.
Casting them in Pewter will thus end up being a necessity for the model to be turned into a Full Option ready RC Model.
By the time this happens I may also be remaking the Wheels in a mix of SLA 3D Prints for the detailed Covers and either 3D Printed ASA or machined Aluminium for the structural Rims as the fully SLA 3D Printed ones have proven to be quite fragile along the Rim edge they ride on. Knowing this I've still decided to paint them so the model wouldn't remain with an unpainted Running Gear for the foreseeable time ( Tracks will receive their paint once the replacement Tracks Pins have arrived ).
Only after fully assembling the model have, I found out that the Drive Sprockets too are kinda wobbly too necessitating a different approach there as well which I expect will end up a mix of casting a slightly oversized Wheel followed by CNC machining it down to spec as a whole or just the areas interfacing with the Gearbox Axles and Tracks. Quite literally the only Running Gear component I'm super happy about how it turned out would be the Idler Wheels - They run perfectly round. Sigh... Many lessons were learned in the making of my first - and still unfinished - scratch build Project but improvements can be made. Just not right now 😁
How the Towing Cables are being routed when the Model has its full complement of Skirts attached to it. Similar to how I did it with the Wooden Block strapped to the rear the Wire Cutters ( or whatever those are ) too have received some hold-down Straps made out of the Photo Etch Framing the Engine Deck Grilles resided in.
So, yea... Other than getting my hands on another one of the super sexy flexible Antennas from DKLMRC there's nothing much to add to the model for aesthetic reasons 🤔
The next most likely Update may either be one on the painting of the Tracks or the addition of working Springs but either of them are going to take their time 😁
MAUS45 (07-27-2022)
