RCU Forums - View Single Post - Flitfire Cub
Thread: Flitfire Cub
Old 07-26-2022 | 07:33 AM
  #46
GiantModeler
Default Ready to Fly!
I spent most of my shop time yesterday taking care of those last minute, but absolutely necessary, details that you must address before that first flight. For example:
Installing the aileron servo.
Here, the servo rails have been epoxied to the underside of the wing.
I secured one aileron in neutral while I adjusted that servo linkage.
Finished. The arms offset to the front will provide aileron differential.
Testing the power system.
With a 4-cell, 4,500 mAh battery reading 16.6 V, the system drew 46 A and consumed 740 W on a 14 x 8 wood prop.
Setting the control throws.
I used the instructions' recommendations for control throws on low rates and boosted the high rates by 30%. Here I was setting the rudder travel. Oh, and I dialed in plenty of exponential.
Adjusting the weight and balance.
When I plopped the Cub on the balancing stand, it was nose heavy, requiring an ounce and a half on the tail. Here is the weight of the model after balancing.
At this weight, I'll have 102 W/lb available at take off.
Let's fly!
