Bit of a nightmare today! After hooking up and adjusting my Ailerons, the 9 gram servo seem to strip the gear at extreme end travel on left side. Quite a job and total waste of time to remove and replace it, as my intentions was to install the MG one but changed my mind to save the weight!.
Well, double the weight but MG one is in and more reliable to control the large four control tabs, more CF had to be fitted to the whole frame to make it flyable, unfortunately adding more weight as I go, so my planed AUW target is just another wishful thinking.
Now fitted with metal gear servo at 19g. AUW!
It needs more carbon!
Adding on weight!
