RCU Forums - View Single Post - Need Henlong multi function unit
Old 07-28-2022 | 11:28 AM
pitstain
Do you own a volt meter? if not they are cheap at Harbor Freight and will help you determine if you have voltage coming out of your control board on the smoke unit's plugs, would be much cheaper than buying a new board and even if you need a new board the volt meter is an indispensable and very useful tool to have around. https://www.harborfreight.com/electr...ter-63759.html
