RCU Forums - View Single Post - Mato smoke unit?
Old 07-29-2022 | 01:35 AM
Crius
You'll have to check the manual, but I'm pretty sure you can turn the smoke on and off from the transmitter. You might want to check and make sure you have it turned on. Also, maybe check voltage at the port. How many ports are you using? For the older smoke units you only need one, but the newer HL units have a separate lead for the heating element and the piston pump. I think a photo might be a big help here.
