Originally Posted by
Dave Wilshere
OK, it will be close. What I’m seeing with the Evo tank is the balance moves forward with a full tank because of the shape, so depending on the pilots requirements, it can go back a little more.
Dave
These are my findings with a Xicoy CG meter on the Ultra Flash Evor:
Fuel in the tank does not change CG until it reaches the flat part of the tank which is when you start seeing the fuel. The CG will move forward a total of 5mm as you fill the tank to full. Also I noticed with CG at 230 and with only the UAT full and the jet resting on it’s tail it will barely stay there without the nose coming back down.
Hope this helps someone.
Rocco
