RCU Forums - View Single Post - Need Henlong multi function unit
Old 08-04-2022 | 09:00 AM
Ghost@amps1
Originally Posted by Crius
The OP said his smoke unit works, but not when it's plugged into the motherboard. That would lead me to believe that he bench tested it. If it's working on the bench but not in the tank, I would check the voltage coming off the mfu. It should be at least 5 volts.
I took one of my smokers and replaced the filament with a 10-ohm 1 watt wire wound resistor and that's almost too much. I have videos of how that came out if anyone wants to see them, I can post them after I get home from work. That was the smoker in my jagdpanther, so if you've seen any of the videos of that running you know that it puts out major smoke. One of these days I really want to try one of those acoustic smokers that Stormin' Normand designed, I just need to get off my lazy Duff and get it done.
I for one, Crius, would like to see that video as it sounds as if you get alot of smoke coming out of the exhaust. "Acoustic" smokers? Never heard of them. Please inform
