RCU Forums - View Single Post - Need Henlong multi function unit
Old 08-05-2022 | 11:57 AM
Ghost@amps1
Originally Posted by Crius
Yeah, Normand did a great job on that smoker and I know he worked long and hard to get that result. If you want true realism in a tiger tank you would probably be better off just to remove the smoker altogether. The real tanks very, very rarely had smoke coming from the rear, but if they did it should be coming through the muffler and the round plate on the top of the muffler is there to disperse any smoke that it did produce. Remember, the tankers did not want exhaust smoke giving them away to the enemy.
Well now that you got me onto this smoker thing, I've come up with another possible brilliant idea. It is, not too insane (I think). I could still use both smoking units in the Tiger I, along with the secondary motherboard, could direct all three of the plastic tubes into just the one - into the one that comes out of the cannon when it fires instead of a measley little slow moving puff of smoke. But I don't know how the blower and heater could work like that without release for such long periods. That's the problem (also remember that they would each be running off separate boards tied into just a single 7.2V battery) so that in itself might be the solution?
