RCU Forums - View Single Post - Steel wire for pull pull tails and making spring for elevator and rudder.
Old 08-08-2022 | 07:48 AM
amsharma
Default Steel wire for pull pull tails and making spring for elevator and rudder.
Need to know which kind steel wire is used for 1 m and 1.5 m DLG to connect servos to elevator and rudder. Also need to know where to buy. And the same information for making the elevator and rudder springs. Beadalon 49 Strand Stainless Steel Bead Stringing Wire.015 in / 0.38 mm, Satin Silver, 30 ft / 9.2 m https://a.co/d/cesuzeV Is this wire good for connecting servos to tail surfaces? Thanks
