I've had a similar problem with older UltraCote and ended up throwing away several large / long (expensive) rolls because it simply didn't apply and stick to itself as newer rolls do. I much prefer Monokote but sadly it isn't like it once was either. Buy some new covering and see how it works for you. A friend tried some of the cheap HK covering for his last two builds and found it quite acceptable. That might be an alternative.
