RCU Forums - View Single Post - Flitfire Cub
Thread: Flitfire Cub
Old 08-15-2022 | 09:13 AM
  #55
GiantModeler
Default Door Outline
During a break in another project, I dug out the Flitfire fuselage to create a door outline. This kit did not provide for an actual door, so an outline will have to do.
First up, I found and unrolled the plans one more time. Then I copied the outline on tracing paper.
This I taped to the right side of the fuselage and . . .
poked a hole through each line intersection. If you squint, you should be able to see the pin holes.
It was simple to connect the dots with 1/16" flat black chart tape. That translates to about a 3/8" gap on the full scale.
Last edited by GiantModeler; 08-15-2022 at 09:17 AM. Reason: Auto editor did not like a particular word
