Originally Posted by
Dansy
‘All I can say it’s supposed to be mounted under, but since it a little more work some don’t…the one I build is mounted under and has been flying great, in it 3th seasons
Manual states the nose gear should be mounted from the bottom. Yes, it’s a pain to get to the screw heads. At the suggestion of Dansy, I used lock nuts in place of the supplied blind nuts. A ball driver can be used from below while the nuts are tightened from the top. Very easy and thanks again Dansy
