RCU Forums - View Single Post - Thrust pipe issue.
Old 09-06-2022 | 02:07 PM
Agrav8ed
Originally Posted by FenderBean
Im not going to say its a 100% the same as a recent issue but I would bet it is. I recently had this same issue with my pipe in a new jet, the problem is the pipe is most likely welded at both ends of the outer/inner walls. This is from the the inner wall expanding from heat and since the outer wall is not free floating at one end it stretches the outer pipe and when it cools it does this.
Who makes the pipe?
It came with the kit. I have to check when I get home tonight but I will have to check and see if the pipe was welded at both ends. I think I have had pipes made similarly in the past but this is the first time I have seen this particular issue.
Tone
